lgds(at)post6.tele.dk Guest
Dave Miller
Posted: Thu Nov 30, 2006 11:44 am Post subject: Oil return hose / 914 |
Gert,
A friend had the same problem with his 914 installation. The line had "carbonized" and was quite brittle.
As far as I remember, he replaced the oil lines with Teflon lines from Aircraft Spruce.
Dave 912S trigear
Gert Dalgaard <lgds(at)post6.tele.dk>
Sent by: owner-europa-list-server(at)matronics.com
11/30/2006 02:16 PM
Please respond to europa-list
cc:
Subject: Oil return hose / 914
Hi
I have had an quite unpleasant experience while doing my annual.
The last month or so I have noticed a ( - very week) smell of "hot oil" sometimes during take of..... and funny enough only during take of.
Could not localize the reason until now when disassembling the different parts under the cowling for the 100 hours/annual check.
It looks like the oil - return - hose have been more than hot under the asbestos - fire - sleeve, and therefore have changed to a kind of "glasslike".
I am sure it would have collapsed within the next hours.
The oil - line have been routed according to Rotax installation manual and instructions from Europa - app. 90 degree to the stb. side and up alongside the intake manifold to the top of the oil-tank
The problem is on that piece of the hose that runs between the turbo unit and the bottom of the engine.
You better put that oil-line on your check - list if you fly behind a 914' ...
FYI - I have never seen higher oil-temp's than 110C (app. 230F) according to the log in my FlyDat.
Have other had similar experiences?
Gert
[url=Times New Roman]OY-GDS [/url]
NB - remember to make a notice about [url=Times New Roman]Endelave '07[/url] in your agenda
garrys(at)tampabay.rr.com Guest
Posted: Thu Nov 30, 2006 3:32 pm Post subject: Oil return hose / 914 |
Actually, I was one of the earliest 914 Europa drivers in the US.......first flight being in 1999. With about 50 hours of flight I had the oil return line "carbonize", and burst in flight. Fortunately, no fire but lots of smoke. The oil return line provided by Europa (or perhaps it was Rotax), was junk. I replaced it with a stainless steel braided oil line, covered the line with firesleave, and further wrapped a stainless steel jacket around the line where it comes closest to the exhaust system. 400 hours later, no problem.
A better solution however, is to turn the banjo fitting at the bottom of the engine so as to face forward. Then route the oil return line forward to the front of the engine and then backward to the oil tank, keeping the line far away from any exhaust components. A "stock" oil return line, fitted per instructions WILL burn up. Please take this advice seriously.
Garry Stout
N4220S A060 Trigear
davidjoyce(at)doctors.org Guest
Posted: Fri Dec 01, 2006 2:04 am Post subject: Oil return hose / 914 |
I wouldn't want to dispute the seriousness of Garry's oil pipe failure, but
I ran my 914 with Europa supplied original oil pipe in their fire sleeve
according to their route, aiming to give maximum clearance from any hot
bits. It clearly became hard and shiny at the front end within few hours
flying but remained that way without problem until I changed it at 4
yrs/400+hrs. The replacement (Europa/Rotax standard) with a slightly thicker
fire sleeve is going well 100hrs later. Regards, David Joyce, G-XSDJ
