hgmckay
Posted: Sun Mar 04, 2007 1:38 pm Post subject: RotaxEngines-List Digest: 1 Msgs - 02/12/07 |
Matt:
In regards to your comment about having a dead battery if you don't
interrupt the circuit between C and B+ while the engine is not running, are
you referring to the Rotax electrical diagram shown in Section 17, on page
46 of the Installation Manual? If so, am I correct to assume that there is a
closed circuit through the regulator due to the fact that the regulator
itself is grounded to the air frame (-), and the (+) is connected to both C
and B+? I don't understand this since the regulator itself should not allow
for a battery drain while the engine is off. Please explain your statement
in further detail.
Hugh McKay
