rfg842(at)cox.net Guest
n801bh(at)netzero.com Guest
w_sweet(at)comcast.net Guest
Posted: Tue Feb 20, 2007 7:01 am Post subject: Auto plugs |
First problem, the ignition harness will not work with auto plugs. To make things simple, just get LSE's CDI dual system, Dynon EFIS D10A or whatever EFIS you like and be done with "the Past".
Wayne
| - The Matronics Engines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
dancfi(at)yahoo.com Guest
Posted: Tue Feb 20, 2007 7:50 am Post subject: Auto plugs |
: Quote: | NOPE !!!!!! ([email]!!!!!!(at)cox.net[/email])
Hey Bob..NOPE AGAIN !. ..the WIRES ends are different and each engine is designed or reguires a specific aircraft plug.The "reach" or distance the plug sticks down into the cylender is different on some plugs. Also There is a "Heat range"for different plugs as I remember (Can anyone out there add to this..I forgot what I knew!)..
Having said all that .some of the older aircraft, Tcraft ect. used iesman mags and DID use auto spark plugs.They worked for low , slow older aircraft but were not considered a great mag.
TV dinner still cooling?
[url=http://us.rd.yahoo.com/evt=49979/*http://tv.yahoo.com/]Check out "Tonight's Picks"[/url] on Yahoo! TV. [quote][b]
archie97(at)earthlink.net Guest
Posted: Tue Feb 20, 2007 8:19 am Post subject: Auto plugs |
Float Flyr
Posted: Tue Feb 20, 2007 3:26 pm Post subject: Auto plugs |
One of th4 things I've never tried to do is replace the plugs on a plane with anything other than the same type of plugs that came off. Generally we used to inspect and clean the plugs every 50 hr. (commercial) and return them to service. At better than $50.00 a pop we weren't too interested in swapping plugs at the drop of a hat. the one rule we did use was if we dropped a plug, the never happened, the second drop would be in the oval filing cabinet.
Good stuff but not why I'm replying... As I said I never replaced a plug with anything but the same type. so I am wondering if the thread and reach of an automotive plug will even fit into the hole??
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
frank.hinde(at)hp.com Guest
Posted: Tue Feb 20, 2007 3:42 pm Post subject: Auto plugs |
Need an adaptor and a standard 3/4" auto plugs fit Lycomings.
Frank
From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Noel Loveys
Sent: Tuesday, February 20, 2007 3:25 PM
To: engines-list(at)matronics.com
Subject: RE: Auto plugs
Noel [quote]
s_korney(at)hotmail.com Guest
Posted: Tue Feb 20, 2007 4:38 pm Post subject: Auto plugs |
Some of the newer Lycoming cylinders are made to accept the 3/4 reach 14 MM
auto plugs.....
Best... Steve
----Original Message Follows----
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Reply-To: engines-list(at)matronics.com
To: <engines-list(at)matronics.com>
Date: Tue, 20 Feb 2007 23:41:44 -0000
Frank
Loveys
Noel
mlas(at)cox.net Guest
Posted: Tue Feb 20, 2007 5:27 pm Post subject: Auto plugs |
My Light Speed system on my IO-550 uses auto plugs….. I change them every 100 hours at $40 a set..
Posted: Wed Feb 21, 2007 6:52 am Post subject: Auto plugs |
And mine are $1.19 each...
Frank
From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Mike
Sent: Tuesday, February 20, 2007 5:27 PM
-----Original Message-----
Sent: Tuesday, February 20, 2007 4:25 PM
2/8/2007
2/8/2007
href="http://www.matronics.com/Navigator?Engines-List">http://www.matronics.com/Navigator?Engines-List
Posted: Thu Feb 22, 2007 6:22 am Post subject: Auto plugs |
Just as a matter of interest, Great Plains, Boys Town, NE, does offer an adapter for a shielded harness to auto plugs. Have not used them but it's a great idea.
Bob, Wichita
