Harmon Rocket with RV 6 wing
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
Rainair
PostPosted: Wed Feb 14, 2007 8:37 am    Post subject: Harmon Rocket with RV 6 wing Reply with quote
Hey Rocketers,
email to Harmon Rocket :
thanx. but, when i have read your booklet i found your are using the rv 6 wings? is that right?? or is it a second opinion? where do i have to make more changes to the rv 4 or rv 6 wings to fit the rocket?
to get the things right rv4 empenage, rv8 tail, rv6 wings and youre parts and ready is the harmon rocket ( ok nearly, only 2000 houres to build).
Of course, we can use the RV6 wings ?
Greats,
Rainer
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
jhstarn(at)verizon.net
PostPosted: Wed Feb 14, 2007 9:08 am    Post subject: Harmon Rocket with RV 6 wing Reply with quote
If I recall correctly we used the -4 wings. Clipped 7" off each, different
wing skins (larger tanks) repositioned the ribs closer together, wider front
bulk heads, firewall etc. Any time you change ANYTHING it affects everything
else. Have not heard about the -6 wings on a HRII Rocket, but then again
we've spent the past six years flying not building. KABONG Do Not Archive
tlc2(at)telus.net
PostPosted: Wed Feb 14, 2007 9:46 am    Post subject: Harmon Rocket with RV 6 wing Reply with quote
The First HR used RV-6 wings......The build (John Harmon) was featured in a
EAA Sport Aviation Magaine issue.
Tim C
Cold Lk.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
