dan(at)rvproject.com Guest
Posted: Mon Jan 22, 2007 7:52 pm Post subject: [SoCAL-RVlist] Fuel collecting in bottom of FAB |
Do you have a purge valve? If so, you should be shutting down with the
purge valve, NOT the mixture. AFP systems don't cut off fuel flow
completely when you pull the mixture (by design). Shut down with the purge
valve and there is no way any significant amount of fuel can continue to
flow through to the cyls if it's working properly.
If you're shutting down with the purge valve and you're still seeing flow,
then question/test the purge valve. New airplane, new tanks...crud could
have gotten up in there. Unlikely but possible.
Sniffle valve...only used on horizontal induction sumps afaik. On your
vertical setup you shouldn't really need it.
)_( Dan
RV-7 N714D (1182 hours)
www.rvproject.com
