Pip Pins
grahamsingleton(at)btinte
PostPosted: Fri Jan 12, 2007 1:05 am    Post subject: Pip Pins Reply with quote
Paul McAllister asked me to forward this question. Could anyone who can
help reply direct to Paul please?
<<Hi all
<paul.mcallister(at)qia.net>
<<I had the wings off so I could fit my Europa in my heated workshop and I put
one of the small pip pins in a safe place....so safe that I can't find it.
Can anyone tell me a US source for these. They are 1/4 in diameter and look
like to be about 1.1" long from the collar to the ball. McMaster Carr has
some thing similar, but not the same.
Thanks, Paul
DanBish
PostPosted: Fri Jan 12, 2007 3:55 pm    Post subject: Pip Pins Reply with quote
They're available from Carr Lane online. Just make sure you measure and order exactly. The part number I show on my invoice is:
CLMF CL-4-BPDR-1.15
Use this link:
http://www.carrlane.com/Catalog/index.cfm/27025071F0B221118070C1C512A0A1F0900101B030010543C1C0C16190D172D252A5E445D
You may have to cut and paste that into your browser. They run $16.25 each. I went ahead and got extras as I tend to hide things from myself too.
Dan
Visit - www.EuropaOwners.org
DanBish
PostPosted: Fri Jan 12, 2007 3:59 pm    Post subject: Pip Pins Reply with quote
On further inspection of the web site, the exact size isn't shown so you may have to special order them from Carr Lane. Also, look to see if they have a distrubutor in your area. They got my order wrong online so I took them back to the local guy who got it wrong two more times before finally coming up with the correct size. But at least you know the exact model number now. Good Luck!
Dan
