Center fuselage
Sean Blair
PostPosted: Tue Jan 31, 2006 9:01 pm    Post subject: Center fuselage Reply with quote
I’m confused……. I’m currently riveting the bottom skins on the center fuselage and if you take a look at the rivet callout, Section 26, page 8, it shows rivets on the leading edge of the F-1077 skin, and nothing on the mating trailing end of the F-1076 skin.  To me this is backward considering the overlap should be with air flow and not against it.  The previous page seems correct with the F-1076 on top of the F-1077.  This is just the opposite of the rivet callout page.  Is my thinking correct?
Thanks!
Sean Blair
#40225
Sean S. Blair
#40225
N967SB (reserved)
rvbuilder(at)sausen.net
PostPosted: Wed Feb 01, 2006 4:28 am    Post subject: Center fuselage Reply with quote
Sean,
  I think this is just how they did the rivet picture.  You are correct in going with the assembly picture on 26-7.
Michael Sausen
-10 #352 Fuselage
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Blair
Sent: Tuesday, January 31, 2006 10:59 PM
Subject: Center fuselage
Thanks!
Sean Blair
#40225
