		MJKTuck(at)cs.com Guest
				 Posted: Sun Jan 29, 2006 7:30 pm    Post subject: Monowheel Brake |
				Hi Folks,
 I finally got around to building one of those wooden blocks that can be used
 to hook onto the main leg (just forward of the wheel) and using a jack raise
 the wheel off the ground. Works great but I figured I would be able to spin the
 wheel.
 It seems the brake pad is touching the brake disc such that a force of
 probably a pound or two is needed to rotate the wheel. This probably accounts for
 the rather polished state of the brake disc - I just assumed this was from
 normal braking.
 I can pull the aircraft along with no problem. My brake handle pulls probably
 an inch or so before I feel the brake pressure so would have thought the
 brake 'relaxed' in off mode. Could it be some kind of lubrication is needed in the
 brake area, I think maybe gunge buildup is somehow preventing the brakes to
 relax.
 Anyone else had a similar problem. Solutions?
 Martin Tuck
 Europa N152MT
 Wichita, Kansas
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		NevEyre(at)aol.com Guest
				 Posted: Mon Jan 30, 2006 12:16 am    Post subject: Monowheel Brake |
				Hi Martin,
 The bores of the two holes in the brake pad plate, are probably grabbing  the
 two pins [ like the action of a ''mastic gun'' ]........ ease the holes
 slightly, and radius the edges, to prevent the corners ''grabbing''.Ensure the
 piston is coming out evenly, push it back with a G [ C?} clamp if it is scewed,
 and pump it out when the caliper is reinstalled.
 Lube with a smear of ''Copperslip'' or similar copper filled grease.
 Nev.
