701 Forced Landing
moorecomp(at)yahoo.com
PostPosted: Tue Jan 17, 2006 7:39 am    Post subject: 701 Forced Landing Reply with quote
Hello,
The Safetydata website shows that a 701 made a forced
landing on Jan. 8th, in Youngstown Ohio after a loss
of oil pressure. Landed in a field. No damage or
injuries. Looks as if it has a Soob for power. Anybody
have more info as to the reason for the loss of oil
pressure, some are flying these engines or are
considering them. "Inquiring minds want to know!"
Craig Moore
A&P 701 builder wannabe
Northern MI
Larry McFarland
PostPosted: Tue Jan 17, 2006 1:29 pm    Post subject: 701 Forced Landing Reply with quote
Craig,
The easiest way to loose oil in a Subaru is to put the pressure sensor
on an extended fitting
purchased from a hardware store in lieu of the automotive fitting.
Automotive fittings are
twice the wall thickness at the threaded ends as those typically found
in hardware stores. I had one
crack from vibration and it sprayed oil in the cowl. Didn't loose
enough to put me
down, but smelled a bit like a startup of the furnace in the fall. I
replaced it with an automotive
fitting that was much shorter and thicker. The other way to loose oil
is to ignore the front seal
at the lower redrive pully. You won't loose it so quickly you have to
do an emergency landing
but it will mess up the cowl just as effectively. I replaced one last
year with a better
sealant.
Larry McFarland - 601HDS Stratus Subaru at www.macsmachine.com
Craig Moore wrote:
Hello,
Craig Moore
Northern MI
Larry McFarland - 601HDS - Stratus
frank.hinde(at)hp.com
PostPosted: Tue Jan 17, 2006 2:03 pm    Post subject: 701 Forced Landing Reply with quote
And an even more spectacular way is....
If you look at the pick up tube in the bottom of the sump, you will find
it can be like 1n inch and quarter above the bottom of the sump. If you
have a STOL airplane and slightly low oil...The oil surges back,
uncovers your pick up tube and you get instant destroyed crank bearings
under full power.
RAM offers a dropped pickup tube, although you can make your own fairly
easily.
Frank
Larry Martin
PostPosted: Tue Jan 17, 2006 7:21 pm    Post subject: 701 Forced Landing Reply with quote
The best way I have found to install a oil sending unit with a Subaru or any
other engine for that matter is to use a 12" grease whip and locate your
sending unit on the firewall. Direct engine vibration is hard on the
sending units. Most of the time they just quit working, I've not seen one
crack open. But, I'm sure it could happen.
Larry, www.skyhawg.com
701 with a Harley, www.skyhawg.com
JetPilot
PostPosted: Sun Jan 22, 2006 10:50 am    Post subject: Re: 701 Forced Landing Reply with quote
Larry Martin wrote:
The best way I have found to install a oil sending unit with a Subaru or any other engine for that matter is to use a 12" grease whip and locate your sending unit on the firewall.
What is a grease whip ??????
Kolb MK-III Xtra, 912-S
Larry Martin
PostPosted: Sat Jan 28, 2006 8:00 am    Post subject: Re: 701 Forced Landing Reply with quote
Sorry, I just saw the question about "what is a grease whip". Guess it didn't make it to my e-mail and I haven't gotten use to checking this forum yet.
Anyway a grease whip is the little hose on the end of a grease gun. It is 1/4 NPF on both ends. They can be purchased at almost any auto parts. I got mine at NAPA. Twelve inch is the most common.
n801bh(at)netzero.com
PostPosted: Sat Jan 28, 2006 12:48 pm    Post subject: 701 Forced Landing Reply with quote
All the ones I have seen are 1/8" pipe thread....
Ben Haas
N801BH
www.haaspowerair.com
BenHaas
N801BH
