wdaniell(at)etb.net.co Guest
Posted: Sat Nov 18, 2006 11:05 am Post subject: tailplane twist |
I have just discovered that I have the port stabilator at 0.6deg (laying the smart level on the aft trailing edge flat surface) different angle from the starboard.
Is this normal, is it supposed to be like this?
Does this matter?
Will
Posted: Sat Nov 18, 2006 2:04 pm Post subject: tailplane twist |
Will
it's not supposed to be like that but I doubt if it matters, I once saw
Pete Clarke take off for a test flight with 1/2 an inch difference in
the level of the trailing edges. He said he couldn't tell the
difference, I was amazed.
Graham
btw Pete was the guy who did all those 12 turn spins etc. Good pilot
William Daniell wrote:
Quote: | I have just discovered that I have the port stabilator at 0.6deg
Does this matter?
Will
carl(at)flyers.freeserve. Guest
Posted: Sat Nov 18, 2006 3:00 pm Post subject: tailplane twist |
Yes, ours is twsted but dosent make a blind bit of difference - been flying
4 years.
The fuselage twisted when we bonded on the top - the tailplane is about .5
of a degree out compared with the wings.
Its not really measurable but obvious when you stand behind the aircraft and
eyeball it.
Carl Pattinson
G-LABS
Posted: Sat Nov 18, 2006 3:33 pm Post subject: tailplane twist |
Thanks to all for setting my mind to rest.
Will
ward.t(at)xtra.co.nz Guest
Posted: Sat Nov 18, 2006 3:51 pm Post subject: tailplane twist |
Will,
I had the same slight fuselage twist. Monowheel Classic #292. Reported it to Andy 7 years ago.
'Not to worry about it' he said, 'flys the same'. Must have been a slight twist in the mould.
As Carl said, just annoys you when you can see it from the back. Helps, I think, with the prop. torque correction?
Anyway, tick that box 'satis' !
Cheers,
Tim Ward
12 Waiwetu Street
Fendalton
Christchurch.
Ph. 64 33515166
MOB 0210640221
4 years.
eyeball it.
Carl Pattinson
G-LABS
