Brake fluid
riddon(at)sent.com
PostPosted: Wed Nov 01, 2006 4:04 am    Post subject: Brake fluid Reply with quote
I am just changing my finger brake setup from Jaymar to Matco and need some aircraft hydraulic fluid to spec. Mil H-5606.
LAS don’t seem to have anything under that description.  Where can I get some?
Richard Iddon G-RIXS
01/11/2006
Brian Davies
PostPosted: Wed Nov 01, 2006 5:28 am    Post subject: Brake fluid Reply with quote
Just been through this, Richard,
Mil H-5606 is the same spec as HF585B-LITRE which is available from Light Aero in 1 litre cans.
Brian Davies
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Richard Iddon
Sent: 01 November 2006 12:05
Subject: Brake fluid
01/11/2006
href="http://www.matronics.com/Navigator?Europa-List">http://www.matron
-- No virus found in this Edition.
30/10/2006
jodel(at)nildram.co.uk
PostPosted: Wed Nov 01, 2006 6:14 am    Post subject: Brake fluid Reply with quote
Richard,
The Matco website says that Dot 5 is okay (if you have some left).
Secondly, check your kit of parts. Mine all matched with the parts list but not the instructions. When I came to fit it I had 2x OR9’s instead of 2xFL14’s .
Simon
Subject: [Norton AntiSpam] Brake fluid
01/11/2006
riddon(at)sent.com
PostPosted: Thu Nov 02, 2006 1:41 am    Post subject: Brake fluid Reply with quote
Thanks Brian.
I have ordered some from LAS now. Unfortunately they didn’t tell me it was available in 1 litre quantities so they are sending me 5! If you ever need any more give me a call.
Regards.
Richard.
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Brian Davies
Sent: 01 November 2006 13:28
Subject: RE: Europa-List: Brake fluid
Brian Davies
Subject: Europa-List: Brake fluid
01/11/2006
30/10/2006
  - The Europa-List Email Forum - --> http://www.matronics.com/Navigator?Europa-List   - NEW MATRONICS WEB FORUMS - -->   - NEW MATRONICS LIST WIKI - -->   - List Contribution Web Site - Thank you for your generous support!     -Matt Dralle, List Admin. -->
01/11/2006
01/11/2006
