wdleonard(at)gmail.com Guest
Posted: Sun Oct 29, 2006 7:58 am Post subject: Serial connections in Parallel? |
I am going to get a Garmin 396or496 and want to connect it's serial output to my SL/30 so it can program the frequencies. I also want to connect it to my Navid, so the NMEA data can steer the auto pilot. But the Garmin only has 1 serial out line.
The output on the Garmin is labeled as "NMEA and VHF" which makes me assume that the data stream has the NMEA data interposed with the VHF programming data.
So the question for you smart guys is: If I connect the serial out signal from the Garmin in parallel to both of the devices, will it work or will there be some sort of signal degradation/interference?
David Leonard
Turbo Rotary RV-6 N4VY
My websites at:
http://members.aol.com/_ht_a/rotaryroster/index.html
http://members.aol.com/_ht_a/vp4skydoc/index.html
http://leonardiniraq.blogspot.com
Larry Bowen
Posted: Sun Oct 29, 2006 8:19 am Post subject: Serial connections in Parallel? |
I'm feeding both my SL30 and TruTrak with the single output from my 396 with no probs.
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
[quote] From: David Leonard [mailto:wdleonard(at)gmail.com]
Sent: Sunday, October 29, 2006 10:58 AM
To: rv-list(at)matronics.com
Subject: Serial connections in Parallel?
David Leonard
My websites at:
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Gary.A.Sobek
Posted: Sun Oct 29, 2006 8:20 am Post subject: Serial connections in Parallel? |
What you are calling Parallel, we Electrical GEEKS call "Daisy Chain". (yes
it is parallel)
Yes it will work. I have my GX60 Serial Port 1 "Daisy Chained" to the SL30
and then to my Trio. Everything works. I tried using Serial Port 2 to run
the Trio but the GX60 only allows me to program it with the correct output
format to only one of the two ports. Therefore I would have been able to use
serial data on only one of the two.
The only problem maybe that it is not the correct format for the Navaid.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
1,964 + Flying Hours So. CA, USA
----Original Message Follows----
Reply-To: rv-list(at)matronics.com
Date: Sun, 29 Oct 2006 07:57:31 -0800
data.
David Leonard
My websites at:
Stay in touch with old friends and meet new ones with Windows Live Spaces
http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
brian.kraut(at)engalt.com Guest
Posted: Sun Oct 29, 2006 8:24 pm Post subject: Serial connections in Parallel? |
You can usually output one NMEA signal to two or three devices in parallel without a problem. Sometimes it gives problems, particularly when you are going to a mix of RS-232 and optocoupler inputs. Some devices also ground the negative side of the input and some devices don't like that.
I work with NMEA every day and it is a strange bird. The standard calls for an RS-422 output, but an optocoupler input. Some units have RS-422 outputs, some have RS-485, some have TTL. Some inputs are RS-422, some are optocoupler, some are TTL, and some are RS-232. Some have the negative side connected to ground on the transmitter, and some on the receiver, and some have neither.
I design ship electronics systems for my day job and we use these buffers when we need to output to more than one device. http://www.engalt.com/prod01.htm. It is usually better to have a separate isolated output to each device. The buffer prevents problems with one device loading down the output and causing problems with other devices. It also has completely independent buffered outputs so if one shorts or has other problems it will not affect the other outputs. I manufacture the buffers so my highly biased opinion is that you should use one.
Brian Kraut
Engineering Alternatives, Inc.
www.engalt.com [quote] --
