Ron Schreck
Joined: 10 Jan 2006 Posts: 94 Location: Gold Hill, NC
Posted: Thu Jan 26, 2006 3:37 am Post subject: Transponder and Static System Check |
Guys,
Thanks for all the responses. I happened to be talking to an FAA rep
yesterday and asked the same question. His response: "The check is not
required at the final inspection, however you cannot use the transponder
(ie: no class B flying) until the certification is complete."
Ron Schreck
RV-8, Final Assembly
Hi guys,
Quote: | > I am assuming that the bi-annual transponder and static system check
Quote: | > needs to be accomplished before I have the final FAA inspection on my
Quote: | > new RV-8. If so, can any of you direct me to someone who wouldn't
mind
Quote: | > traveling to Gold Hill Airpark to do this for me at a reasonable
rate?
Quote: | > Perhaps I can get the final inspection without having the transponder
Quote: | > check if I don't fly anywhere a transponder is required or if I just
Quote: | > don't have the transponder installed??? Give me your $00.02.
Quote: | > RV-8, final assembly
Quote: | > Gold Hill Airpark (NC25)
| - The Matronics RVSouthEast-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Thu Jan 26, 2006 8:25 am Post subject: Transponder and Static System Check |
"The check is not required at the final inspection, however you cannot use
the transponder
Ron,
I would add to the FAA guys statement............"And no flying under the
Mode C veil".
That required me to complete the certification prior to my first flight.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
