Fuel cap / Cobra reinforcement
rparigor(at)suffolk.lib.n
PostPosted: Thu Oct 12, 2006 8:41 pm    Post subject: Fuel cap / Cobra reinforcement Reply with quote
Just finished up my fuel cap / Cobra reinforcement tonight.
2BID with PeelPly
1/8" Balsa
1BID
I will list details in case anyone is interested:
2 BID from seam of fuse, to door frame, and 3" aft of Cobra and above
filler rebate.
Staggered each layer 1/2" shorter aft of Cobra and above filler.
After 2BID I covered with peel ply and let cure.
I bonded in place 1/8" balsa 6.5" wide. I selected 4" wide Balsa that was
long grain, very flexible width, to conform to fuse curve. I used JB Weld
Kwik (4 minute) buttered Balsa with Spackle knife. I sanded the ends of
balsa down to 1/16" prior to bondimg in place.
Then floxed edges of Balsa and laid up final BID.
I find JBing small pieces is a reasonable procedure if you don't have
necessary stuff for vacuum bagging.
I covered filler hole with Balsa. Once cured will cut filler hole, dig out
some Balsa and fill with flox.
Ron Parigoris
garrys(at)tampabay.rr.com
PostPosted: Fri Oct 13, 2006 12:12 pm    Post subject: Fuel cap / Cobra reinforcement Reply with quote
Sorry, but what's a "Cobra"?
Garry Stout
PostPosted: Fri Oct 13, 2006 4:43 pm    Post subject: Fuel cap / Cobra reinforcement Reply with quote
Hello Garry
"Sorry, but what's a "Cobra"?"
The "Cobra" is the roto molded piece of white plastic that goes between
the filler cap and the fuel tank rubber elbow, it looks like the snake.
Ron Parigoris
