Strobe Wiring
Jeff Moreau
PostPosted: Tue Oct 03, 2006 11:16 am    Post subject: Strobe Wiring Reply with quote
I am installing Whelen wingtip strobes on my RV8. I have installed a molex multi-pin plug at the wing root in the event that I ever have to remove the wings.
Does anyone feel that this is inviting a problem with electrial "noise" in my system. I know that this is a shielded cable. I am a novice and would welcome any comments or suggestions.
Jeff
Jeff Moreau
RV8A
Virginia Beach, VA
larry(at)macsmachine.com
PostPosted: Tue Oct 03, 2006 12:10 pm    Post subject: Strobe Wiring Reply with quote
Jeff,
Having installed a system with similar plugs etc, I could only say that
I've never experienced electrical noise with the strobes active or not.
They've been unplugged several times. Good plugs........
Larry McFarland - 601HDS at www.macsmachine.com
Jeff
Jeff Moreau
RV8A
Virginia Beach, VA
http://forums.matronics.com/viewtopic.php?p=65535#65535
roger(at)nwtradingpost.co
PostPosted: Wed Oct 04, 2006 12:54 pm    Post subject: Strobe Wiring Reply with quote
Jeff
I recently attended the EAA electrical workshop and asked the same question
(different plane!)
The answer I got was that the shielding should be bridged, that is solder
tags to the shielding on either side and connect through the molex plug
Hope this is helpful
Roger Venables
Zenith 701
Kenmore, WA
