Stick Transfer function
Mark Phillips in TN
PostPosted: Wed Sep 27, 2006 9:54 am    Post subject: Stick Transfer function Reply with quote
Howdy again-
Thanks to all who offered suggestions for the lighted, engraved rocker switches- now have two sources, Pacific/Gulf Coast and Aerocraft.
Next question. I am investigating how to swap all stick switch functions from L to R (Infinity grip) by some reliable, safe means.  About 8 wires minimum (4-way trim, CWS, PTT, gnd). I would prefer a simple switch as opposed to using relays (4PDTx2) but I'm beginning to think there is no source for an 8PDT switch.
Any suggestions or am I barking up the wrong tree and there's a simpler way to do this?
THANKS!
Mark Phillips do not archive
From The PossumWorks...
N6030X(at)DaveMorris.com
PostPosted: Wed Sep 27, 2006 10:26 am    Post subject: Stick Transfer function Reply with quote
Many of those can just be paralleled as long as you don' t have two
people fighting each other over the use of the switches. And I'm
assuming here you mean you have two Infinity control sticks, one for
pilot and one for copilot. The PTT for each stick would control that
person's PTT connection to the radios, so you don't want to switch
that. Trim you're only going to be using one-at-a-time, so you
should be able to parallel those. etc.
Dave Morris
At 12:53 PM 9/27/2006, you wrote:
Howdy again-
THANKS!
Deems Davis
PostPosted: Wed Sep 27, 2006 11:01 am    Post subject: Stick Transfer function Reply with quote
Dave, that answers part of a question that I had, as I thought that I
might connect both sticks in this manner (parallel), and add a grandson
switch that broke the grounds on the co-pilot grip to disable it if
desired. I recall that a lot of builders use relays to wire their
control sticks. What is the objective of using relays? Is it to solve
the 'contention' issue between the pilot/co-pilot?
Deems Davis # 406
Panel/Finishing
http://deemsrv10.com/
Dave N6030X wrote:
<N6030X(at)DaveMorris.com>
that. Trim you're only going to be using one-at-a-time, so you should
Dave Morris
> Howdy again-
> THANKS!
