Battery kill switch operation.
gz(at)comgz.com
PostPosted: Mon Sep 18, 2006 11:14 pm    Post subject: Battery kill switch operation. Reply with quote
Good morning all,
I'm considering the use of a manual battery kill, like this one:
http://www.flamingriver.com/index.cfm/page/ptype=product/product_id=60/category_id=133/home_id=76/mode=prod/prd60.htm
This is because my battery is located under passenger's seat in my Stag-Ezr
and it would easy pilot's reach in electrical emergency.
This would replace my present battery contactor, mounted in the usual
position.
My question is: is there any reason to use the manual battery kill switch on
the negative battery post (ground) like I'm told is used on racing cars,
rather than on positive post, like the usual relay battery contactor?
Myself, I don't see any difference, unless someone enlighten me.
Thanks.
Gianni Zuliani.
http://www.comgz.com/stag-ez.htm
nuckollsr(at)cox.net
PostPosted: Tue Sep 19, 2006 3:40 am    Post subject: Battery kill switch operation. Reply with quote
At 09:10 AM 9/19/2006 +0200, you wrote:
Good morning all,
position.
Thanks.
Gianni Zuliani.
No difference.
< with experiment. >
< --Lawrence M. Krauss >
