Fiberglass / Epoxy NO Paint
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List
Rcaprd(at)aol.com
PostPosted: Sat Jan 21, 2006 9:49 am    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
Here's something I've been wanting to try for a long time:
I just ordered some Epoxy Premium Pigment from AS&S.
Prep the plywood on the wing, use 1080 deck cloth with straight resin, while still tacky - squeegee resin with micro-balloons and Epoxy Pigment, then I'm going to use this stuff in the last two layers of West System 105 Resin /  206 Hardener, and if I can get to flow & look flat and glossy, I'm  NOT  going to paint the wing.
So...waddya think ???
Chuck Gantzer
NX770CG
- The Matronics Tailwind-List Email Forum -
http://www.matronics.com/Navigator?Tailwind-List
gptailwind(at)msn.com
PostPosted: Sat Jan 21, 2006 11:21 am    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Chuck-- You may not need the micro balloons. Gordon 9168Q
dan42101(at)yahoo.com
PostPosted: Sat Jan 21, 2006 2:33 pm    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
Chuck,
Sounds like a lot to do before it sets up on you.  You made need helpers and cold weather...
-Dan
Chuck Gantzer
NX770CG
Yahoo! Photos
Got holiday prints? [url=http://us.rd.yahoo.com/mail_us/taglines/holidayprints/*http://pa.yahoo.com/*http://us.rd.yahoo.com/mail_us/taglines/photos/evt=38089/*http://pg.photos.yahoo.com/ph//print_splash]See all the ways[/url] to get quality prints in your hands ASAP.
Rcaprd(at)aol.com
PostPosted: Sat Jan 21, 2006 7:05 pm    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
In a message dated 1/21/2006 1:21:46 PM Central Standard Time, gptailwind(at)msn.com writes:
Gordon,
The reason for the micro balloons is to fill the weave, after the cloth is applied with straight epoxy.  The final 2 coats will not have micro balloons in it.
Chuck G.
NX770CG
Rcaprd(at)aol.com
PostPosted: Sat Jan 21, 2006 7:27 pm    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
In a message dated 1/21/2006 4:34:28 PM Central Standard Time, dan42101(at)yahoo.com writes:
Chuck,
-Dan
Dan,
The only thing different in the process, is that the epoxy will have some white pigment in it.  Cloth will be applied without any pigment.
Chuck G.
NX770CG
PostPosted: Sat Jan 21, 2006 8:24 pm    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
Chuck,
If you don't get any poo poos about the modus operandi from the ones who have done it... take pictures!  The rest of us will be grateful.
-Dan
Chuck,
-Dan
Dan,
Chuck G.
NX770CG
Yahoo! Photos
Ring in the New Year with [url=http://us.rd.yahoo.com/mail_us/taglines/photos/*http://pa.yahoo.com/*http://us.rd.yahoo.com/mail_us/taglines/photos/evt=38087/*http://pg.photos.yahoo.com/ph//page?.file=calendar_splash.html&.dir=]Photo Calendars[/url]. Add photos, events, holidays, whatever.
IslPilot(at)aol.com
PostPosted: Sat Jan 21, 2006 8:43 pm    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
I have played with pigment in the epoxy and it is not opaque enough.  At a certain point you start to lose some strength with the large quantity of pigment trying to get it opaque.
Try a small sample first on some test pieces and see what happens.
Paul
Paul F. Baron
Cell# 773-551-3713
IslPilot(at)aol.com
PostPosted: Sat Jan 21, 2006 8:45 pm    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
Also remember that the epoxy needs to be protected from the UV and I don't believe the pigment will be enough.  If you call Gougeon, and ask for a Tech Rep they will give you their opinion.  They have been very supportive in not laughing at some of my ideas.
Paul
Paul F. Baron
Cell# 773-551-3713
mytyweav(at)earthlink.net
PostPosted: Sun Jan 22, 2006 12:20 am    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
Chuck, you are wasting your time. It will not work and you will have to
paint regardless. Apparently, You are reading too much into the hype of
marketing and sales from AS&S. Do yourself a favor and forget the idea and
just use good epoxy and glass to finish the surface of your wing. Then,
apply a good primer for the paint you intend to use. Over the years, you
will be glad you took the time to do it right.
Weav
Original Message:
Date: Sat, 21 Jan 2006 14:33:17 -0800 (PST)
To: tailwind-list(at)matronics.com
Subject: Re: Fiberglass / Epoxy NO Paint
Chuck,
and cold weather...
-Dan
Chuck Gantzer
NX770CG
Yahoo! Photos
Got holiday prints? See all the ways to get quality prints in your hands
ASAP.
mail2web - Check your email from the web at
http://mail2web.com/ .
Rcaprd(at)AOL.COM
PostPosted: Sun Jan 22, 2006 7:27 pm    Post subject: Fiberglass / Epoxy NO Paint Reply with quote
In a message dated 1/21/2006 10:46:12 PM Central Standard Time, IslPilot(at)aol.com writes:
Paul,
I found my copy of the West System User Manual, and it says the same thing you did...the pigment will NOT be enough to protect the epoxy from UV rays.
So much for the No Paint idea...
Thank you all for your responses.
Chuck G.
NX770CG
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List All times are GMT - 8 Hours
