CS Crankshaft end - what's it look like
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
recapen(at)earthlink.net
PostPosted: Fri Sep 01, 2006 7:47 am    Post subject: CS Crankshaft end - what's it look like Reply with quote
Reposting since my original post failed to make it......
Fellow listers,
I'm trying to determine what the prop end of the crankshaft is supposed to look
like when it is set up for a constant speed prop.
Folks have written about plugs - but that doesn't tell me what to look for.
If it's plugged, should I only see the plug? If it's not plugged, what
does the inside look like?
FWIW, I'm not seeing 'just a plug' - I'm seeing stuff in there -
looks like a bar going across with a notch cut in to it...maybe to allow a tool
to get all the way in to the back.
Anyone have any drawings or photographs?
I know this is one that I don't want to have the wrong way...
Ralph Capen
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
grant.piper(at)bigpond.co
PostPosted: Fri Sep 01, 2006 7:18 pm    Post subject: CS Crankshaft end - what's it look like Reply with quote
Hi Ralph,
I converted my CS crankshaft to FP. There is a Lycoming Service Bulletin
that describes it and the parts (kit) you nee (sorry, can't recall the
number). Go to the Lyc 'site and do a search, you should find it.
Grant
RV-4 VH-PIO 250hrs
wbecker(at)centurytel.net
PostPosted: Sat Sep 02, 2006 6:33 am    Post subject: CS Crankshaft end - what's it look like Reply with quote
The Lycoming S.L. that covers converting from constant speed to fixed pitch
is S.L 1435. This has a very good drawing to show how it should be both
ways.
Bill Becker
PostPosted: Sat Sep 02, 2006 5:16 pm    Post subject: CS Crankshaft end - what's it look like Reply with quote
All I can get to at the Lycoming site is the list of Service Instructions.
Any hints on how to drill down to the one (1435) and see it?
PostPosted: Sat Sep 02, 2006 6:58 pm    Post subject: CS Crankshaft end - what's it look like Reply with quote
Ralph,
I can try to e mail it to you, maybe Monday. Bill Becker
PostPosted: Sat Sep 02, 2006 7:10 pm    Post subject: CS Crankshaft end - what's it look like Reply with quote
Ralph,
e mail me at wbecker(at)centurytel.net and I will help you out.
Bill Becker
Hopperdhh(at)aol.com
PostPosted: Sun Sep 03, 2006 4:52 am    Post subject: CS Crankshaft end - what's it look like Reply with quote
Ralph,
The Vans assembly manual has SI 1435 reproduced in the ENGINE AND PROPELLER INSTALLATION section. The Lycoming overhaul manual has some information in it also.
Hope this helps,
Dan Hopper
RV-7A constant speed
In a message dated 9/2/2006 10:59:29 P.M. Eastern Daylight Time, wbecker(at)centurytel.net writes:
[quote]--> LycomingEngines-List message posted by: "William Becker" <wbecker(at)centurytel.net>
Ralph,
PostPosted: Sun Sep 03, 2006 5:55 am    Post subject: CS Crankshaft end - what's it look like Reply with quote
Thanks - I'll look in there too. Just thinking that I'll need to get stuff from Lycoming directly since they put out SB's that reference other documentation on a regular basis.
Ralph
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
