mono angle of repose
fklein(at)orcasonline.com
PostPosted: Fri Sep 01, 2006 9:40 am    Post subject: mono angle of repose Reply with quote
All,
By any chance, has anyone ever determined the angle of the XS monowheel
between the fuselage datum and the ground with the gear
extended?...either at empty weight, or at full gross weight (assuming
that at full gross, the gear angle changes a bit)?
Fred
A194
davidjoyce(at)doctors.org
PostPosted: Sat Sep 02, 2006 1:39 am    Post subject: mono angle of repose Reply with quote
Fred, I happen to have measured mine last week at 6.7degrees. That's with
fuel in to give it a weight of around 900lbs Regards, David Joyce, G-XSDJ
PostPosted: Sat Sep 02, 2006 1:17 pm    Post subject: mono angle of repose Reply with quote
David...excellent, thank you very much.
Fred
A194
DO NOT ARCHIVE
On Saturday, September 2, 2006, at 02:36 AM, David Joyce wrote:
<davidjoyce(at)doctors.org.uk>
with
G-XSDJ
