sales(at)6440autoparts.co Guest
Posted: Tue Aug 29, 2006 11:40 am Post subject: HAND HELD COM ANTENNA CONNECTION |
I was just looking at
http://www.aeroelectric.com/articles/commtap/commtap.html and if I
understand it correctly this will break the antenna connection from the in
dash com (disabling it)and allow the hand help to use the antenna. I would
prefer to be able to use both radio's at once if needed. I have read here on
Aeroelectric that a "t" type bnc connector will cause the antenna to loose
some of it's range. Is there a better way to use both radios at the same
time ?
Randy
brian-av(at)lloyd.com Guest
Posted: Tue Aug 29, 2006 2:13 pm Post subject: HAND HELD COM ANTENNA CONNECTION |
On Aug 29, 2006, at 12:40 PM, 6440 Auto Parts wrote:
Quote: |
<sales(at)6440autoparts.com>
I was just looking at http://www.aeroelectric.com/articles/
commtap/commtap.html and if I understand it correctly this will
break the antenna connection from the in dash com (disabling it)and
allow the hand help to use the antenna. I would prefer to be able
to loose some of it's range. Is there a better way to use both
radios at the same time ?
There is no good way to connect two radios that operate in the same
band to the same antenna, i.e. you can't connect two comm radios to
the same antenna. If you put in a 'T' connector to connect both
radios to the same antenna, odds are very good that the first time
you transmit on one radio you will destroy the other.
So the best answer is, "add another antenna."
If you want to connect a handheld radio to your regular comm antenna,
bring the com antenna coax to a place you can readily reach (like
just under the leading edge of the panel) and terminate it with a BNC
female connector. Bring the coax from your comm radio to the same
place terminated in a BNC male. Connect them together. If you need to
plug your hand-held into the comm antenna because your main comm has
failed, reach under the panel, disconnect the BNC male from the
regular comm, and attach the antenna cable from your handheld to the
now-free BNC female that goes to the antenna.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
FLYaDIVE(at)aol.com Guest
Posted: Tue Aug 29, 2006 5:53 pm Post subject: HAND HELD COM ANTENNA CONNECTION |
In a message dated 8/29/06 5:19:47 PM Eastern Daylight Time,
sales(at)6440autoparts.com writes:
on
time ?
Randy
Randy:
I hope someone got to you sooner than I on your question?
You CANNOT use a 'T' fitting to use both radios at the same time.
The HUGE problem in doing so is that when you TRANSMIT the output of one
radio will go directly into the other radio and BLOWOUT that radio. And since
there is also a mismatch it could even do damage to the transmit radio,
The ONLY way I know of to use one antenna and two radios is to disconnect one
radio from the antenna. Which brings up a second problem. When you
disconnect the panel Com it is sitting without an antenna/load. If you were to hit
the transmit button on the stick you could blow the output circuit of the Com
radio.
Best way around this is to have two antennas. Second best way is to shout
off the panel Com radio when using the HH radio.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
bicyclop(at)pacbell.net Guest
Posted: Tue Aug 29, 2006 8:49 pm Post subject: HAND HELD COM ANTENNA CONNECTION |
There actually is a way to use two Com radios on one antenna. Bob Archer
sells an antenna switch that connects both radios while receiving and
disconnects the passive radio when either transmits. I think he can be
reached at:
bobsantennas(at)earthlink.net
Google him up and you'll find all kinds of interesting stuff.
Pax,
Ed Holyoke
dsvs(at)comcast.net Guest
Posted: Tue Aug 29, 2006 9:05 pm Post subject: HAND HELD COM ANTENNA CONNECTION |
Ed,
Comant also sells the same thing. Don
