nuckollsr(at)cox.net Guest
Posted: Wed Aug 23, 2006 6:24 am Post subject: Potentiometers question |
At 02:26 PM 8/22/2006 -0400, you wrote:
Bob,
I am building a RV10 and am using your wiring diagram, dual Alt dual bus. I
am also installing a blower motor to use as a source to blow heated air on
to the windscreen. I have sourced a blower, via west marine that is 12
volts 6amp and will work I think quite nice. I would like to have a
variable switch/potentiometer to control the unit, to turn it on as well as
control the fan speed. I have been to DIGIKEY and Mouser to find a POT that
would work, the problem is that I don't know what values to use 5K 10K 15K
25K etc&..for this application.
Can you provide any guidance&.Your help is appreciated
You're going to need something heftier than a panel-mounted,
stand-alone potentiometer. Potentiometers are limited to
currents on the order of a few milliamperes. Rheostats (really
BIG potentiometers) are available to handle much larger
currents on the order of amps . . . but they get so hot
and are so large that mounting them on the panel (or anywhere
else in the airplane) is not practical.
You need a variable duty cycle motor controller. A number of
folks here on the List have been modifying a kit offered by
Marlin P Jones at:
http://www.mpja.com/productview.asp?product=4057+MD
This product is advertised as capable of handling 10A
of motor current. As you can see, it's CONTROLLED by
a relatively small potentiometer (milliamps) but the
motor current is carried by a transistor on a heatsink
(amps). I know nothing about this kit and it has some
obvious packaging issues for aircraft. The electronics
board needs to be mounted in some kind of box and the
potentiometer brought out on leads to be mounted on the
panel.
Suggest you join the AeroElectric List and talk with
folks who have used this kit. They can probably offer
a variety of options for utilizing this kit in your
project.
< with experiment. >
< --Lawrence M. Krauss >
klehman(at)albedo.net Guest
Posted: Wed Aug 23, 2006 10:09 am Post subject: Potentiometers question |
sorry I've lost the original post but that is a huge fan for defrost. If
you really think you need it you could also look at an automotive fan
speed control arrangement.
For just blowing air up through the instrument glareshield I found that
a little axial fan as seen in computer power supplies seems to work fine
for me. No speed control required.
Ken
<nuckollsr(at)cox.net>
Bob,
bus. I am also installing a blower motor to use as a source to blow
heated air on to the windscreen. I have sourced a blower, via west
marine that is 12 volts 6amp and will work I think quite nice. I would
like to have a variable switch/potentiometer to control the unit, to
turn it on as well as control the fan speed. I have been to DIGIKEY
and Mouser to find a POT that would work, the problem is that I don't
know what values to use 5K 10K 15K 25K etc&..for this application.
Marlin P Jones at:
panel.
project.
