N6030X(at)DaveMorris.com Guest
Posted: Wed Aug 23, 2006 4:46 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
How about putting the starter switch on the throttle, so you can do
an in-flight restart without taking your hands off the sticks and throttle.
Dave Morris
At 07:22 AM 8/23/2006, you wrote:
Given that this started as a discussion of the hazards of having the flap
control mounted on the stick, wouldn't mounting the speed brake control on
the stick pose a similar hazard?
Gilles.Thesee(at)ac-greno Guest
Posted: Wed Aug 23, 2006 5:07 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Hi Dave,
How about putting the starter switch on the throttle, so you can do an
Er, how many times in a flight do you restart your engine ?
The last time I had to was 16 years ago, when the prop stopped in a
vertical manoeuver during an advanced aerobatic contest. And yes,
reaching for the starter switch during the 4 Gs pull out proved an
interesting exercice. No one noticed from the ground.
But what is the point in normal cases ?
One very good location for the starter switch, is near the fuel valve,
with an arrangement such that the switch is covered by the valve handle
when in the closed position. No starting with the fuel valve closed. The
ubiquitous (in France) Robin DR400 have this feature.
PTT
Trims
Auto pilot disengage
That's all I see necessary on the throttle and stick in a civilian
airplane.
Someone mentionned Intercom PTT, what's the use for such a device ?
Best regards,
Gilles
http://contrails.free.fr
brian-av(at)lloyd.com Guest
Posted: Wed Aug 23, 2006 5:47 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
On Aug 23, 2006, at 5:44 AM, Dave N6030X wrote:
<N6030X(at)DaveMorris.com>
throttle.
How often do you expect to do this? How often might you do this by
accident? What happens if you do this by accident? Given how
infrequent its use would be I would think that leaving it on the
panel is not a real problem.
BTW, I would add speed brakes to my list of things that should be on
the throttle (stick-equipped aircraft with the throttle in your left
hand) along with the radio and intercom PTTs.
Brian Lloyd 361 Catterline Way
brian HYPHEN av AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
Posted: Wed Aug 23, 2006 5:55 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Hi Brian,
Why a PTT for the intercom ?
Gilles,
Posted: Wed Aug 23, 2006 6:05 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
On Aug 23, 2006, at 6:04 AM, Gilles Thesee wrote:
| Quote: | PTT
Trims
airplane.'
I would put the PTT on the throttle and I would add the speed brake
too. And you are right on the auto pilot disengage. That is one of
the things I forgot and *must* be on the stick or yoke.
| Quote: | Someone mentionned Intercom PTT, what's the use for such a device ?
Some aircraft have such a high noise level that a voice-operated
intercom won't work properly. You use a PTT to activated your mic
into the intercom. Helicopters are known for this as are many
military aircraft.
Posted: Wed Aug 23, 2006 8:15 am Post subject: Ergonomics (was: Flap switches/relay wiring) |
Brian,
intercom won't work properly. You use a PTT to activated your mic into
the intercom. Helicopters are known for this as are many military
aircraft.
Understand.
Thank you for responding.
Best regards,
Gilles,
