Rotax oil sender with switch
rparigor(at)suffolk.lib.n
PostPosted: Fri Jan 20, 2006 1:02 pm    Post subject: Rotax oil sender with switch Reply with quote
Lockwood Aviation now sells a oil pressure sender with a extra switch
contact on it (VDO).
I will use the switch to run a low oil pressure indicator, and also to
power a relay that will stop my Hobbs from running.
Ron Parigoris
scrimm
PostPosted: Fri Jan 20, 2006 2:48 pm    Post subject: Rotax oil sender with switch Reply with quote
Ron, got a part number?
Steve
Steve Crimm
N42AH
PostPosted: Fri Jan 20, 2006 10:25 pm    Post subject: Rotax oil sender with switch Reply with quote
Hello Steve
No part number this second, Tisha is sending me one.
Give her a call, or I can give it to you once my order arrives.
Ron P.
"Ron, got a part number?"
