Albert Gardner
Posted: Tue Aug 08, 2006 7:13 am Post subject: GPS & Autopilot Setup |
I am using a ControlVision GPS (HP ipaq 4700) connected to my Trio EZ Pilot Autopilot and it is not working properly. Is anyone else using this same setup? I’m trying to resolve the problem and I’m wondering if it’s working for someone else.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
sbuc(at)hiwaay.net Guest
Posted: Tue Aug 08, 2006 7:45 am Post subject: GPS & Autopilot Setup |
Albert Gardner wrote:
| Quote: | I am using a ControlVision GPS (HP ipaq 4700) connected to my Trio EZ
Albert Gardner
Albert, the versions of AWM that I tried with the Trio did not provide
the standard NMEA protocol that the EZ-Pilot requires. I understand
there was considerable effort on the part of Trio to convince Control
Vision to standardize the NMEA output of AWM but it seems that may not
have happened.
Sam Buchanan
http://thervjournal.com
Posted: Tue Aug 08, 2006 10:14 am Post subject: GPS & Autopilot Setup |
Sam Buchanan wrote:
> Albert Gardner
have happened.
Sam Buchanan
I just received word from Trio (they monitor this list!) that apparently
the latest version of Anywhere Map does indeed send out a standardized
NMEA data stream.
Sam Buchanan
FLYaDIVE(at)aol.com Guest
Posted: Tue Aug 08, 2006 4:58 pm Post subject: GPS & Autopilot Setup |
In a message dated 8/8/06 11:49:31 AM Eastern Daylight Time, sbuc(at)hiwaay.net
writes:
| Quote: | the versions of AWM that I tried with the Trio did not provide
have happened.
Sam Buchanan
Sam:
What type of output does AWM use? The three I a familiar with are:
RS-232
IEEE
and the
NEMA versions. There are a few versions of NEMA.
The next question is what input does the Trio require?
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
Albert Gardner
Posted: Tue Aug 08, 2006 6:15 pm Post subject: GPS & Autopilot Setup |
Well, the plot thickens. Talking to AWM leads me to believe that they think
they are putting out the "right stuff." Trio thinks they will work if the
"right stuff" comes in. I'm taking the whole shebang over to El Cajon (Trio
Avionics) tomorrow to see if they can find a problem. Trio is great to work
with so I am very optimistic.
Albert Gardner
Yuma, AZ
RV-10 N991RV |
Posted: Tue Aug 08, 2006 6:42 pm Post subject: GPS & Autopilot Setup |
FLYaDIVE(at)aol.com wrote:
writes:
> have happened.
> Sam Buchanan
Sam:
RS-232
IEEE
and the
Barry
"Chop'd Liver"
Barry, you must have missed the update I sent out shortly after posting
the above message. Trio informed me that they have had success getting
the latest version of AWM to drive the EZ-Pilot. I suggest you contact
Trio if you need more specific info on their system.
Both AWM and the EZ-Pilot use NMEA data. I have had success driving the
EZ-Pilot with a Lowrance Airmap 100 and Airmap 1000. Fellow RVers in the
area also get excellent results with Garmin units. Apparently earlier
versions of AWM did not send all the sentences of the NMEA data or the
sentences were in non-standard form. Since the guys at Trio are very
particular about assuring their unit is flying only on good data, the
EZ-Pilot filters would reject non-standard data protocol.
Sam Buchanan
