Video camera connection
rsmith52
PostPosted: Fri Mar 01, 2024 8:01 am    Post subject: Video camera connection Reply with quote
I am trying to install a forward looking video camera in my Bearhawk cowling to help with taxiing, its pretty blind over the cowling. I purchased a backup camera that installs in a 9/16" hole. I have the Garmin G3X, the video connection on the screens is a BNC connector. Supported formats are NTSC, PAL, and SECAM. Garmin says to connect the video with RG179 coax. The camera video connector has a single composite video plug with a red 20 ga pigtail coming out the back of the plug. I cut the connector off one end and found that the cable contains 3 24ga wires, white, black and red. I would like to install a BNC connector at the camera so it can be disconnected for cowl removal. Then use a coax cable to connect to the G3X. I have no idea how to wire this. I have $17 invested in the camera, if someone knows of a small camera that comes wired with a BNC connector, I am all over it.
david(at)carter.net
PostPosted: Fri Mar 01, 2024 8:26 am    Post subject: Video camera connection Reply with quote
I used this adapter on the back of the G3X Touch display to connect the backup camera's RCA plug to the G3X's BNC connector.
https://www.amazon.com/gp/product/B082D2RGCB/ref=ppx_yo_dt_b_search_asin_title
It sounds like the camera you are using is similar to the one I used:
https://www.amazon.com/gp/product/B07QBMNVVB/ref=ppx_yo_dt_b_search_asin_title
David Carter
david(at)carter.net (david(at)carter.net)
On Fri, Mar 1, 2024 at 11:02 AM Rod Smith <rodsmith52(at)yahoo.com (rodsmith52(at)yahoo.com)> wrote:
