dav1111(at)cox.net Guest
Posted: Sat Jul 29, 2006 5:13 pm Post subject: Tunnel Temps |
Second flight today in N710RV. Checked the forward tunnel area for high temps. Used the bare leg method. Stuck my bare left leg up against the tunnel wall and held it there for at least five minutes. No problem, even confirmed after landing that I still had hair on my leg (just in case my 33 month build had killed the nerves in the leg and I didn't feel the heat).
After hearing all the tunnel heat issues raised in the posts I did the following:
1. Bought a roll of engine gasket material at NAPA and cut out gaskets to install between the firewall and the heat vent boxes. (Don't remember for sure but I think this tip came from Tim Olson as 90% of the my help tips have - Thanks Tim).
2. Installed an RTV gasket around the inside of the heat vent doors after install by beading the RVT around the opening, placing a piece of wax paper over the RTV and closing the door with the cable. After setup of the RTV I removed the wax paper and re-closed the door. (Install tip from Jesse Saint - Thanks Jesse).
3. RTV'ed around the outside of each heat vent box.
4. Installed foil faced insulation on the bottom of the tunnel floor and over the inside of the firewall (used this method on my RV-6A firewall after it was built and it made a huge difference). I did not build a false floor in the tunnel, only put the insulation up to the edge of the fuel flow transducer and fuel pump.
5. Installed sound proofing foam insulation under the floor and on the sidewalls.
Hope these tips help.
By the way N710RV flies like a dream. Working on wheel pants and gear leg fairings between flights.
Russ Daves
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Sat Jul 29, 2006 9:59 pm Post subject: Tunnel Temps |
Russ,
What kind of foil faced insulation did you use? What was the actual insulating material? Where did you buy it?
Kevin
40494
_________________ Kevin
40494
do not archive |
LarryRosen
Posted: Sun Jul 30, 2006 2:50 am Post subject: Tunnel Temps |
Any more details on the engine gasket material you used?
Larry Rosen
#356
N205EN - Doors
Russell Daves wrote:
| Quote: | Second flight today in N710RV. Checked the forward tunnel area for
following:
the sidewalls.
Russ Daves
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Sun Jul 30, 2006 5:32 am Post subject: Tunnel Temps |
Just ask at any auto parts store for a roll of engine gasket material. It
comes in about 8 inch by 24 inch roll I think.
Russ Daves
effectus(at)rogers.com Guest
Posted: Sun Jul 30, 2006 7:35 am Post subject: Tunnel Temps |
Russ,
What thickness of SuperSoundproofing did you use?
Dave Hertner
Posted: Sun Jul 30, 2006 10:35 am Post subject: Tunnel Temps |
1/2 inch
Russ Daves
Posted: Sun Jul 30, 2006 10:37 am Post subject: Tunnel Temps |
Dave,
Ignore my first response, I was half asleep.
The stuff I got from SuperSoundproofing.org for the firewall and tunnel floor only came in one thickness, it was called "Super Soundproofing Thermal Aluminum faced fire retardant foil one side insulator blanket". It really wasn't for sound proofing as much as for heat proofing.
The soundproofing I got from Wicks Aircraft Supply was 1/2" for the floors and side panels.
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Sun Jul 30, 2006 5:39 pm Post subject: Tunnel Temps |
The baffle material works as well and is already on hand. Both the red hi
temp silicon and the thinner black works great.
Steve d
40205
rvbuilder(at)sausen.net Guest
Posted: Mon Jul 31, 2006 7:37 am Post subject: Tunnel Temps |
I spent a little time talking to the guy from EPM.AV at OSH. We were discussing the heat problem and he is going to send me prototype heater boxes that are two part separated by a ceramic gasket for a full thermal break. I'll send some pictures when I get it in a couple weeks.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves
Sent: Saturday, July 29, 2006 8:11 PM
Subject: Tunnel Temps
Russ Daves
KiloPapa
Posted: Mon Jul 31, 2006 12:35 pm Post subject: Tunnel Temps |
Thanks for the info.
Kevin
40494
do not archive |
