Radio Noise
jluckey(at)pacbell.net
PostPosted: Mon Sep 25, 2023 10:14 am    Post subject: Radio Noise Reply with quote
Seeking with wisdom of the Collective.
I'm hearing an intermittent "crackle" in the audio of an ICOM com radio but only when engine is running. It is not ignition noise.  I know this because when I turn-off the squelch, I can hear the Ignition "ripple" in the background. This "crackle" is a different sound.  (sorry, it's hard to describe sounds with words)
Environment:
Older ICOM A200 Com radio
There is a Dynon intercom in the system.
Old Narco transponder
2-place airplane, headsets only, no speaker
IO-360 with conventional mags
Symptoms:
1. A loud short-duration "crackle" occurs randomly every 3 to 10 seconds accompanied by a RECEIVE indication on the face of the radio.
2. Only happens when engine is running
3. This "crackle" is breaking squelch
My first guess was a loose connection in the antenna circuit. I have checked the antenna connection at the antenna and it appears to be OK. The coax is split-out and soldered to the antenna. The solder connection looks good and nothing is loose at the antenna.
The radio is very difficult to get to. The airplane seems to have been "built around" the avionics.
I'm trying to check the easy stuff first before tearing-up the air frame to gain access to the radio.
Suggestions?
-Jeff
finn.lassen(at)verizon.ne
PostPosted: Mon Sep 25, 2023 11:49 am    Post subject: Radio Noise Reply with quote
Do you have strobes installed and on when you hear that?
Independent of engine RPM (vibrations)?
Finn
Environment:
Symptoms:
Suggestions?
-Jeff
PostPosted: Mon Sep 25, 2023 12:46 pm    Post subject: Radio Noise Reply with quote
Symptoms:
This suggests that the noise is coming in thru
the antenna. Try disconnecting the antenna to
see if noise goes away. Also, noises coming in
thru this pathway are affected by the radio's
volume control.
Does turning alternator on/off make and difference?
Does running one mag at a time make a difference?
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
