TR-4 Elevator Trim tab range of movement
mike(at)vision499.com
PostPosted: Mon Sep 18, 2023 2:45 pm    Post subject: TR-4 Elevator Trim tab range of movement Reply with quote
I just had the inspector here and he wants a spec on the range of movement for the elevator trim tab. Could you please let me know if you have that info or recorded the range that you have
Thanks very much
aeromomentum(at)yahoo.com
PostPosted: Mon Sep 18, 2023 3:33 pm    Post subject: TR-4 Elevator Trim tab range of movement Reply with quote
I have never seen a specified range for the trim tab travel. Keep in mind that if you followed the plans for the trim tab size, they tend to be way under what is needed. Most people end up extending the trim tab.
Since control surfaces tend to be fairly effective and linear to about 25 to 30 degrees, this is what I would try.
Mark
On Monday, 18 September 2023 at 06:48:35 pm GMT-4, <mike(at)vision499.com> wrote:
Thanks very much
