EarthX Battery Charging Graph
PostPosted: Mon Jul 31, 2023 7:57 am    Post subject: EarthX Battery Charging Graph Reply with quote
Suggested Changes to EarthX Graphs:
https://earthxbatteries.com/dual-bus-lithium-battery-design/
Remove "TIME" from the graph.
Relabel "Voltage" to "Voltage Regulator Setpoint".
Of course the setpoint will not change unless adjusted by a mechanic.
The graph shows what battery charging current would be at various regulator voltage settings.
Putting a diode in series with a battery has the same effect as reducing the voltage regulator setpoint.
Joe Gores
