email(at)jaredyates.com Guest
Posted: Tue May 23, 2023 7:13 am Post subject: Best Connector for 8awg-12awg fuse link |
I'm installing a 40a B&C alternator as a backup in the z101b architecture. I figure I need 8-gauge wire for the b-lead which will make for a 12-gauge fuse link. Is there an elegant connector to use for that 8-12 junction, or should I just solder and heat shrink them?
Ceengland
Posted: Tue May 23, 2023 8:34 am Post subject: Best Connector for 8awg-12awg fuse link |
On Tue, May 23, 2023 at 10:15 AM Jared Yates <email(at)jaredyates.com> wrote:
[quote] I'm installing a 40a B&C alternator as a backup in the z101b architecture
_________________ Charlie |
Posted: Tue May 23, 2023 9:40 am Post subject: Best Connector for 8awg-12awg fuse link |
Good thinking, if that happens, do I want it to happen?
On Tue, May 23, 2023, 13:39 Roger&Jean <rnjcurtis(at)charter.net (rnjcurtis(at)charter.net)> wrote:
Quote: | --> AeroElectric-List message posted by: Roger&Jean <rnjcurtis(at)charter.net (rnjcurtis(at)charter.net)>
If you solder a fuse link, wouldn't the solder melt and possibily separate before the copper fuse link?
Roger
On May 23, 2023 12:33 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
> On Tue, May 23, 2023 at 10:15 AM Jared Yates <email(at)jaredyates.com (email(at)jaredyates.com)> wrote:
> Here's the 1st thing I hit; I just googled '8 gauge to 12 gauge butt splice'.
> Having said that, IIRC I cheated and shed a few strands from the 8 ga where it entered a yellow 10/12 butt splice (please don't tell anyone). Another option is to use a straight 8 ga butt splice with Bob's trick of jamming in a few 1/2" lengths of solid copper to fill out the fuselink side to 8 ga, but 8 ga splices tend to be bare copper too, which forces the use of heat shrink. Might as well solder & save the search.
> All the other butt splice options I found were quite pricey in small quantities. If I hadn't cheated with the 10/12, I'd have soldered.
> Charlie
> Virus-free.www.avast.com
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
Ceengland
Posted: Tue May 23, 2023 10:06 am Post subject: Best Connector for 8awg-12awg fuse link |
Fusible links typically open at the middle of the run of link wire. The closer you get to either end, the more 'heat sink' effect you get from the bigger wire or the hardware on each end.
Besides, if the wire's hot enough to melt solder (>360 degrees), you want something to open up.
Roger
> Charlie
Virus-free.www.avast.com[url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Posted: Fri May 26, 2023 5:57 am Post subject: Best Connector for 8awg-12awg fuse link |
At 11:33 AM 5/23/2023, you wrote:
Quote: | On Tue, May 23, 2023 at 10:15 AM Jared Yates <email(at)jaredyates.com (email(at)jaredyates.com)> wrote:
I'm installing a 40a B&C alternator as a backup in the z101b architecture. I figure I need 8-gauge wire for the b-lead which will make for a 12-gauge fuse link. |
10AWG is big enough for this short, single strand run hence a 14AWG fusible
link is called for. A yellow PDIG butt splice should do it. You may need
to double the strip length on the fusible link and double it back to
boost the amount of 14AWG copper in the splice.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
