Solved: PV50 lead screw bearing
IanGale
PostPosted: Mon Apr 24, 2023 11:50 pm    Post subject: Solved: PV50 lead screw bearing Reply with quote
My Arplast PV50 lead screw bearing has gone a bit crunchy so needs replacement. I’m looking for tips and advice please from anyone who has done this before I start to disassemble. At the same time I’m looking to create some spares so if anyone has the dimensions for the lead screw, bearing and the other parts, or can help me as to where they sourced them, thet would be much appreciated. Thanks in advance
IanGale
PostPosted: Sun Apr 30, 2023 11:35 pm    Post subject: Re: Help please: PV50 lead screw Reply with quote
Replying to my own post in case it helps someone else.
The bearing is 61800-2Z-SKF and is pretty common so all the usual suspects stock it. I’ll update when I replace mine and post some images.
Matt Dovey
PostPosted: Tue May 09, 2023 9:02 am    Post subject: Re: Solved: PV50 lead screw bearing Reply with quote
Here are the replacement miroswitches I used to replace the old ones on my prop. https://uk.rs-online.com/web/p/micro-switches/6866840
These are the diodes I used https://uk.rs-online.com/web/p/schottky-diodes-rectifiers/7484975.
This is the part number of the motor with out the gearbox P/N 2224U006SR.
