CJ Nose oleo seals
jay-dub
PostPosted: Tue Apr 11, 2023 6:13 am    Post subject: CJ Nose oleo seals Reply with quote
Anyone know where I can get hold of a set of seals for the nose oleo, please? It has deflated and won't reinflate.
Some urgency as the annual is due...... Embarassed
CJ owner
TXMike
PostPosted: Tue Apr 11, 2023 8:05 am    Post subject: Re: CJ Nose oleo seals Reply with quote
I got mine (Yak52 nose) from Jill and team at http://m-14p.com/
I am about to order kits for both mains as well.
She is also very active on the Yak FB group.
My nose collapsed and the orings were very brittle. It wasn't a terrible rebuild but it was for sure a two person job. I am no expert but happy to share my experience with you if that somehow helps you.
Mike
jay-dub
PostPosted: Tue Apr 11, 2023 8:28 am    Post subject: Re: CJ Nose oleo seals Reply with quote
Thanks for your kind offer. In my part of the world, owner maintenance is pretty limited so it will be going to our maintenance organisation for the work.
I’ll try Jill if I have no luck locally.
CJ owner
TXMike
PostPosted: Tue Apr 11, 2023 8:38 am    Post subject: Re: CJ Nose oleo seals Reply with quote
Sounds good.
If you don't mind sharing your experience after the work is done I would love to hear how it went.
(I forget how spoiled we are over here sometimes... I can't imagine having to just write a check every single time it gets touched)
woodja51
PostPosted: Mon Apr 24, 2023 2:25 pm    Post subject: Re: CJ Nose oleo seals Reply with quote
You can get the seals, new valve and piston rings top seal from China easily enough. Probably less than a few hundred dollars with freight all up. I just overhauled one as a spare that was flat .. easy job - as long as you find the locking grub screw first .. getting the centring collar off / on is pretty simply too .. so far mine has held pressure sitting in shed last few months ..
