Trutrak Digiflite II flat pack
dlm34077(at)gmail.com
PostPosted: Sat Jun 25, 2022 6:20 pm    Post subject: Trutrak Digiflite II flat pack Reply with quote
My AP has been in my aircraft since 2008 with only an aileron servo overhaul. A problem has developed with the screen backlighting. Sometimes it works and sometimes it does not; I finally determined that the screen seems to be loose in the box. A slight pressure on the left side of the screen makes the backlighting work normally and the display is readable in the daylight. There seems to be a loose connection in the screen to the unit. I found that King is now maintaining TT APs. Has anyone else had this problem? How did you get it fixed? locally or otherwise and how much does it cost?
jesse(at)saintaviation.co
PostPosted: Sat Jun 25, 2022 7:04 pm    Post subject: Trutrak Digiflite II flat pack Reply with quote
Mid Continent Instruments is the service center for the TruTrak auto pilots. I’d give them a call and verify they can service that unit. Either way, out of warranty, I would open it up and see if there is a loose plug you can snap into place.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
