Lord motor mount replacement
SPurpura(at)AOL.COM
PostPosted: Mon Jan 16, 2006 4:18 pm    Post subject: Lord motor mount replacement Reply with quote
I am replacing the soft O-200 type Lord mounts with the stiffer ones supplied
by Europa.
Do any of you lister's know the length of the spacers in the FWF kit ?
Thank's, Sam N77EU
paul.mcallister
PostPosted: Mon Jan 16, 2006 5:12 pm    Post subject: Lord motor mount replacement Reply with quote
Sam,
You are going to have to make up 4 spacers 1.7" long out of .5" tube with an
internal ID of .306" I seem to recall that the standard ones would not
compress the Lord mounts enough when I made mine.
Paul
bryan(at)blackballclub.co
PostPosted: Wed Jan 18, 2006 12:17 pm    Post subject: Lord motor mount replacement Reply with quote
Regarding changing the engine mountings. I advise that you discuss this with
Andy before going ahead. I have just replaced my mountings after five year's
service. He has advised me not to go to softer alternatives. When Europa
tried it they discovered that the engine developed a noticeable sag after a
while.
They have developed an alternative design using the same bushes, but
reducing the compression by securing with slightly longer bolts and spacers.
Cheers Bryan
