Does anyone have a warpdrive blade for an airmaster
wdaniell.longport(at)gmai
PostPosted: Wed Jan 19, 2022 5:03 pm    Post subject: Does anyone have a warpdrive blade for an airmaster Reply with quote
A couple of colombian friends landed their mono motorglider wheel up.
They need a warpdrive wide cord blade and some bits from a hub.
(I already suggested bud and to call the factory but they asked me to put this on the forum)
Will
William Daniell
+1 786 878 0246
John Wighton
PostPosted: Thu Jan 20, 2022 12:36 am    Post subject: Re: Does anyone have a warpdrive blade for an airmaster Reply with quote
I had 2 almost pristine blades but cut them up as the blades are sold as matched sets. You should not replace part of the blade system.
It is possible that you might get lucky and find a blade from the same manufacturing batch. But it would need careful balancing (spanwise and chordwise) in order to match the dynamics of the existing blades.
A new set is not so expensive (just a long wait).
Good luck.
John Wighton
Europa XS trigear G-IPOD
