Static port location
kitfox555(at)sbcglobal.ne
PostPosted: Sun Jan 09, 2022 6:43 pm    Post subject: Static port location Reply with quote
I have a model 2 and having problems with airspeed and want to place a external static port but would like to know where to put it. Right now it’s inside ,behind fire wall
kitfox(at)mcn.org
PostPosted: Sun Jan 09, 2022 7:00 pm    Post subject: Static port location Reply with quote
I had the same issue with my Model 4 years ago.
Tried several static port change ideas. None made any difference.
Turned out the airspeed indicator had a small internal leak.
Replaced the ASI and its been fine since.
Kirby Cramer
Kitfox 4 NSI Subaru, N45KC Vans RV7A O-360, N445KC
FAA Experimental Aircraft Repairman & EAA Life Member
26 Rollingview Lane Fallbrook, CA 92028
KirbyCramer(at)gmail.com
760-505-3173
YouTube: Cramer's Classic Cycles
rtoth4310(at)gmail.com
PostPosted: Mon Jan 10, 2022 3:58 am    Post subject: Static port location Reply with quote
I have mine external left side of fuselage just forward of horizontal stabilizer in about the middle of the fuselage. No issues!
Guy Buchanan
PostPosted: Mon Jan 10, 2022 9:55 am    Post subject: Static port location Reply with quote
My 4 had it left side, about half way back to the horizontal. It was off
by about 10%. I did better just disconnecting the static at the
instrument. Since I used GPS my airspeed didn't matter terribly much so
I didn't spend much time trying to make it accurate. Were the GPS to
fail my airspeed was close enough to allow me to DR navigate reasonably
well, and as far as stall speeds and the like went, I used my own tested
values. I remember, however, that you had to be careful with slips when
you had a single external static; your indicated airspeed could be
wildly different, one side to the other. A glider I once flew, (Grob
102,) had, I think, six static ports, to ensure accurate airspeed no
matter the slip angle.
Guy Buchanan
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
michaelgibbs(at)cox.net
PostPosted: Mon Jan 10, 2022 10:16 am    Post subject: Static port location Reply with quote
My Model 4 had, and the current Series 7 has, one on each side, about mid-way between the wings and horizontal stabilizer. They have a straight tube between them with a “T” in the middle that runs to the instrument panel. Seems to work OK.
Mike
Phoenix, AZ
On Jan 10, 2022, at 10:57 AM, Guy Buchanan <gebuchanan(at)cox.net> wrote:
My 4 had it left side, about half way back to the horizontal. It was off by about 10%. I did better just disconnecting the static at the instrument. Since I used GPS my airspeed didn't matter terribly much so I didn't spend much time trying to make it accurate. Were the GPS to fail my airspeed was close enough to allow me to DR navigate reasonably well, and as far as stall speeds and the like went, I used my own tested values. I remember, however, that you had to be careful with slips when you had a single external static; your indicated airspeed could be wildly different, one side to the other. A glider I once flew, (Grob 102,) had, I think, six static ports, to ensure accurate airspeed no matter the slip angle.
Guy Buchanan
> Sent from my iPhone
PostPosted: Mon Jan 10, 2022 3:36 pm    Post subject: Static port location Reply with quote
Mike
Phoenix, AZ
> Guy Buchanan
>> Sent from my iPhone
Guy Buchanan
> Sent from my iPhone
PostPosted: Mon Jan 10, 2022 3:37 pm    Post subject: Static port location Reply with quote
> Sent from my iPhone
