Duplicate ACS keys
docclv(at)windstream.net
PostPosted: Thu Oct 21, 2021 10:44 am    Post subject: Duplicate ACS keys Reply with quote
Phil: Can a guy order ANY ACS numbered key from ACS even though the key
in question is not on the key's number list that Aircraft Spruce has?
How do you place an order for a key to ACS? I can't get them to even
reply. Doc
digidocs
PostPosted: Thu Oct 21, 2021 10:54 am    Post subject: Duplicate ACS keys Reply with quote
If you need a copy, I've found the local locksmith can make them.
On Thu, Oct 21, 2021 at 1:47 PM Doc <docclv(at)windstream.net (docclv(at)windstream.net)> wrote:
--> RV10-List message posted by: Doc <docclv(at)windstream.net (docclv(at)windstream.net)>
reply.  Doc
philperry9
PostPosted: Thu Oct 21, 2021 11:05 am    Post subject: Duplicate ACS keys Reply with quote
Just order this key… (double cut so it’s more hassle-fee when you insert it. I also got the rubber boot option to soften the edges of the key.)
https://www.aircraftspruce.com/catalog/elpages/igswitcheskey.php?clickkey=10386
At the time of checkout, you’ll be prompted to enter the key code from your existing key.
Pretty easy.
Phil
reply. Doc
trigo(at)mail.telepac.pt
PostPosted: Thu Oct 21, 2021 12:42 pm    Post subject: Duplicate ACS keys Reply with quote
Guys
If you are talking about those ACS keys for the keyed ignition switch or for the aircraft doors, they can be duplicated in any neighbourhood locksmith.
Carlos
Enviado do meu iPhone
No dia 21/10/2021, às 19:50, Doc <docclv(at)windstream.net> escreveu:
Phil: Can a guy order ANY ACS numbered key from ACS even though the key in question is not on the key's number list that Aircraft Spruce has? How do you place an order for a key to ACS? I can't get them to even reply. Doc
