Antenna Coax Routing
trichmond(at)obermeyer.co
PostPosted: Thu Jul 27, 2006 8:49 am    Post subject: Antenna Coax Routing Reply with quote
Folks,
This might be a newbie question but I’m giving it a shot none the less.  I have an RV-7A (or part of one at this point) in which I am planning on mounting my VOR and marker beacon antennas in the wingtips (one in each tip).  Can I route my antenna coax in the same conduit with the nav, landing, and strobe lights or should I do a separate run some distance away to avoid any potential interference.  The current set up has one transformer for the strobes mounted in the fuselage and a shielded wire running to the wing tips (the strobes ground back at the transformer).  The nav, landing and taxi lights are grounded locally on the wingtips.
My other concern is that at some point I would like to upgrade to a HID system for the landing/taxi lights which would require a local power transformer by the light.  Has anybody had any experience with interference caused by these next to an antenna?
Thanks for any input.
Todd R. Richmond
RV-7A
frank.hinde(at)hp.com
PostPosted: Thu Jul 27, 2006 10:09 am    Post subject: Antenna Coax Routing Reply with quote
Todd Just a thought but....
If you mount a comm in one wingtip, Nav in the other and marker bacon in the bottom of the cowl  you'll have no com attenna sticking out in the breeze (at least one less if you have more than one com) and you'll reduce the amount of coazxyou have to run out to the wings.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Todd Richmond
Sent: Thursday, July 27, 2006 9:42 AM
Subject: Antenna Coax Routing
Folks,
Todd R. Richmond
RV-7A
brian
PostPosted: Fri Jul 28, 2006 5:05 am    Post subject: Antenna Coax Routing Reply with quote
If you plan to use the VOR antenna for general VOR navigation, it
might not work all that well as it is not going to receive well in
all directions. If you plan to use it for flying an ILS where the
transmitter is likely to be right in front of you, it will probably
work pretty well.
A blade type antenna on the VS is still the best way to go but a
catwhisker antenna on the top of the VS or bottom of the fuselage is
pretty good.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
