Tail wheel tow bars
rehn(at)rockisland.com
PostPosted: Sat Jul 10, 2021 2:26 pm    Post subject: Tail wheel tow bars Reply with quote
I’ve been using a strap with a eye that connects on each side of the wheel to pull my Europa around and also to pick up the tail wheel if needed.
Looking for something with wheels that requires little lifting and easier on the back! Would like to hear about what works for the Europa, the strap is fine for travel, as it’s very small and portable and generally not needed so much. Need something for home base.
Jerry
Europa XS Mono
914
aspenbuild(at)me.com
PostPosted: Sat Jul 10, 2021 9:45 pm    Post subject: Tail wheel tow bars Reply with quote
Jerry, 20mm ply, about 350mm square with a small castor bolted to each corner. Cut a 100mm hole in centre to accept tail wheel. Makes it all much easier.
Richard S
Jerry
Europa XS Mono
914
