Aileron balance tubes and weights?
Charlie Mike
PostPosted: Wed Jun 23, 2021 5:25 pm    Post subject: Aileron balance tubes and weights? Reply with quote
My slingshot has the aileron balance tubes in place. I have the weights that go inside to neutralize control. There are no holes in either to secure the weights. The drawings show a bolt thru set up. …. Are you using these? And if so, how are the weights secured in the tubes?
Kolb Slingshot 582, C gearbox.
