Is there a switch configuration that will do this?
PostPosted: Mon Jun 21, 2021 8:24 am    Post subject: Is there a switch configuration that will do this? Reply with quote
This switch with addition of two
diodes and the resistor cited above can be configured
to accomplish the switching functions you requested.
See attached:
P.S. those 'loose' components present a small
packaging problem. I think I'd fabricate an
assembly-under-heat-shrink of the three compoents
with wires coming out each end.
Use 1/2" dual wall heat shrink . . . that's
how I packaged a few hundred crowbar ov management
modules.
Your finished assembly will be about 1-1/2 inches
long and 3/8" in diameter. It would tie nicely
into an adjacent wire bundle. I've got all the
materials in stock. I could build one up for you.
out of that stuff?"
