Yak 52 Flow Restrictors
RedX
PostPosted: Sun Jun 06, 2021 4:00 pm    Post subject: Yak 52 Flow Restrictors Reply with quote
OK,
I know there are suppose to be flow restrictors in the system to the gear actuators.
Questions:
1. How many?
2. What locations?
3. Source of replacements?
4. Any other information I should know?
Red X Yak
dsavarese0812(at)bellsout
PostPosted: Sun Jun 06, 2021 4:12 pm    Post subject: Yak 52 Flow Restrictors Reply with quote
Should be one reducer on the main side air hose going to the shuttle
valve on the down side of each actuator.  Not on the emergency side.
You may also consider adding one to each hose going to the upside of
each gear actuator.  If you add them to the up side, it will slow down
the gear retraction.  So it's up to you.  I don't recommend it though.
Contact Jill at M14P for them.
A. Dennis Savarese
334-546-8182
www.yak-52.com
On 6/6/2021 8:00 PM, RedX wrote:
OK,
Questions:
1. How many?
2. What locations?
Red X Yak
http://forums.matronics.com/viewtopic.php?p=502252#502252
RedX
PostPosted: Sun Jun 06, 2021 4:20 pm    Post subject: Re: Yak 52 Flow Restrictors Reply with quote
Thanks Dennis
Joe Oram
Red X Yak
RedX
PostPosted: Mon Jun 21, 2021 3:46 am    Post subject: Re: Yak 52 Flow Restrictors (UPDATE) Reply with quote
All,
We installed the flow restrictors on all inputs to the gear actuators.
What a difference in the gear cycle time and no banging to the stops.
Best $30 you can spend on your Yak/CJ
Red X Yak
PostPosted: Mon Jun 21, 2021 4:34 am    Post subject: Yak 52 Flow Restrictors Reply with quote
Hopefully you only put them on the main side and not the emergency side.
Dennis
A. Dennis Savarese
334-546-8182
www.yak-52.com
On 6/21/2021 7:46 AM, RedX wrote:
All,
Red X Yak
http://forums.matronics.com/viewtopic.php?p=502500#502500
