Next Generation Z-Figures
PostPosted: Wed Apr 15, 2020 7:48 am    Post subject: Next Generation Z-Figures Reply with quote
At 07:35 AM 4/15/2020, you wrote:
--> AeroElectric-List message posted by: John Livingston <livingjw(at)earthlink.net>
WRT Z101, during operation would you advise setting the Aux switches ON or OFF?
For normal ops, not necessary. When MAIN BUS is hot,
all busses are hot. Even if you're flying on the AUX
ALT, no repositioning of other switches is necessary
-unless- selective load reductions are necessary based
on criticality of individual busses.
Distribution of loads to the various busses is part
of your design goals for crafting Plan A, everything
up and running -OR- Plan B, continued flight to intended
destination on the AUX alternator.
It may not be the same for every project. But if
one feels better with alternate feeds ON . . . it
doesn't hurt anything. There are no risks that arise
from 'mis-positioning' any switch.
Like the legacy z-figures, this suite of drawings will
be supported with copious notes including a pre-flight
checklist that will exercise all funtionalities
before launching into the blue.
pilot_pat
PostPosted: Fri Apr 16, 2021 2:53 am    Post subject: Re: Next Generation Z-Figures Reply with quote
Please advise where I may find the "copious notes including a pre-flight checklist that will exercise all functionalities before launching into the blue."
I understand if they are not issued yet; I did try to find them.
Pat
PostPosted: Mon Apr 19, 2021 11:57 am    Post subject: Next Generation Z-Figures Reply with quote
At 05:53 AM 4/16/2021, you wrote:
--> AeroElectric-List message posted by: "pilot_pat" <ocainp(at)gmail.com>
Pat
Work in progress . . . slow . . .
What airplane are you building?
Consider Z101 which will replace all
previous configurations.
Join us on the List and we can craft
a checklist appropriate to the
configuration that fits your
needs.
out of that stuff?"
pilot_pat
PostPosted: Tue Apr 20, 2021 4:20 am    Post subject: Notes Regarding Figure Z-101B Reply with quote
Bob, I'm building an RV9A using Z101B, Garmin G3X and G5 boxes, external power contactor and thinking about a TCW 6 A-hr IBBS set up per the G3X install manual figure 27-1.5.
You've crafted a lot into the design, and I wanted to make sure I understand how it was meant to be used, particularly switching during equipment failures.
I believe I'm already on the list...
Pat
mburbidg(at)gmail.com
PostPosted: Tue Apr 20, 2021 6:38 am    Post subject: Next Generation Z-Figures Reply with quote
Can I get a link to the Z101B system diagram?
Michael-
On 4/20/21, 5:27 AM, "owner-aeroelectric-list-server(at)matronics.com on behalf of pilot_pat" <owner-aeroelectric-list-server(at)matronics.com on behalf of ocainp(at)gmail.com> wrote:
Pat
http://forums.matronics.com/viewtopic.php?p=501448#501448
johnbright
PostPosted: Tue Apr 20, 2021 7:32 am    Post subject: Re: Next Generation Z-Figures Reply with quote
Michael
In folder Adobe Architecture PDFs at http://www.aeroelectric.com/PPS/
John Bright, RV-6A, at FWF, O-360
N1921R links
glastar(at)gmx.net
PostPosted: Tue Apr 20, 2021 12:51 pm    Post subject: Next Generation Z-Figures Reply with quote
www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z101B.pdf
<www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z101B.pdf>
http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z101B.dwg
<http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z101B.dwg>
http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z101B(R14).dwg
<http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z101B(R14).dwg>
Michael-
Pat
PostPosted: Tue Apr 20, 2021 1:09 pm    Post subject: Next Generation Z-Figures Reply with quote
Okay. With Z101, ANY time the BAT/ALT switch is ON,
ALL BUSSES are powered irrespective of any other
switch condition.
Which busses are you planning to incorporate?
TCW IBBS? standby battery? Not planning on
a second alternator? No PM protocol for
battery reliability?
What's the engine configuration with respect
to fuel/ignition?
out of that stuff?"
pilot_pat
PostPosted: Wed Apr 21, 2021 3:42 am    Post subject: Re: Next Generation Z-Figures Reply with quote
Planning on Battery, Main, Engine and Aux Buses, connected as shown in Z101B.
There will be a second alternator using a B&C regulator rather than the Ford; no second battery aside from IBBS.
TCW 6 Ah IBBS would be charged from main bus and power via "aircraft power 2" inputs the PFD, the engine monitor GEA24, the ADHRS GSU25 and the GPS20A.
Main battery (16 Ah): plan on load testing at annual and operational testing on first daily engine start.
Engine fuel injection will be Airflow Performance FM-150 and ignition will be dual pmag 114s fed from the engine bus for starting. Fuel pump is an Airflow Performance Auxiliary pump assembly.
Pat
PostPosted: Sun Apr 25, 2021 8:19 am    Post subject: Next Generation Z-Figures Reply with quote
Okay, make a list of the breakers/fuses on a bus/by/bus
basis.
Battery:
Main:
Aux:
Engine:
out of that stuff?"
