Fwd: Kolb-List Digest: 3 Msgs - 04/04/21
lcottrell
PostPosted: Mon Apr 05, 2021 11:06 am    Post subject: Fwd: Kolb-List Digest: 3 Msgs - 04/04/21 Reply with quote
---------- Forwarded message ---------
From: Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)>
Date: Mon, Apr 5, 2021 at 1:04 PM
Subject: Re: Kolb-List Digest: 3 Msgs - 04/04/21
To: kolb-list(at)matronics.com (kolb-list(at)matronics.com) <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
I've followed this thread through all the different replies, and I once rode in a Mark three that dived for the ground when full power was pushed. Didn't like it at all, and didn't feel that it was airworthy either. Anyway I was curious about the difference in my HKS on my firestar. So I stuck the ?protractor? on the bottom of the wing as it sat in my hanger and found that the bottom of the wing measured 38 degrees, I then stuck it on the engine plate and found that it read 30 degrees. So my 60 horse engine is 8 degrees flatter than the wing.
With this configuration and trimmed for straight and level flight at 5400 rpm's. Max sustained cruise is 5800 for the HKS. If I go to full throttle of 6100 rpms the plane climbs, rather than nosing down. In other words I can climb at neutral input from the stick.
Not real sure if any of this answers your question or not, but it seems to me that a difference of 8 degrees flatter compared to the wing should get one to where the plane operates best.
for what its worth.
Larry
The older I get, the less tolerant I am of those who are intolerant of others.
Jerry-TS-MkII
PostPosted: Mon Apr 05, 2021 11:42 am    Post subject: Fwd: Kolb-List Digest: 3 Msgs - 04/04/21 Reply with quote
Hi Larry!
When you are at cruise is the wing 6-8° positive? That would put the
engine thrust at 0. What's the stab angle, as compared to your wing/engine
measurements. I'd guess it's less than the engine, to produce some tail
down to balance the engine push over effects.
On Mon, 5 Apr 2021 13:05:43 -0600, Larry Cottrell
To: kolb-list(at)matronics.com [2]
Ive followed this thread through all the different replies, and I once
pushed. Didnt like it at all, and didnt feel that it was airworthy
sat
I
5400
rpms. Max sustained cruise is 5800 for the HKS. If I go to full throttle
for what its worth.
Larry
