Kolb-List Digest: 2 Msgs - 03/27/21
nazz57(at)yahoo.com
PostPosted: Sun Mar 28, 2021 9:24 pm    Post subject: Kolb-List Digest: 2 Msgs - 03/27/21 Reply with quote
i'm refering to "weight and balance" ... i weigh 250 lbs and obviously i don't want too much weight in the front..
Time: 08:00:12 PM PST US
From: Larry Cottrell <lcottrell1020(at)gmail.com (lcottrell1020(at)gmail.com)>
Subject: Re: too fat .....
It all depends on how much your plane weighs ready for flight. Empty
weight, and the difference of 750 pounds. I believe the gross weight for
the Firestar is 750.
It will still fly at that weight, but performs like a cub. That assumes
that you will fit in the seat.
Larry
On Sat, Mar 27, 2021 at 8:39 PM Tim Hrib <tim_hrib(at)hotmail.com (tim_hrib(at)hotmail.com)> wrote:
what is the maximum weight you can put in the cockpit of a FireStar 2?
..... too fat Tim
stuart(at)harnerfarm.net
PostPosted: Mon Mar 29, 2021 6:19 am    Post subject: Kolb-List Digest: 2 Msgs - 03/27/21 Reply with quote
If you have the empty CG location, the fully loaded W&B should be a straight forward calculation. Then all you need to know is the CG envelope.
IF you don’t have a current W&B about all you can do is re-weigh and do the calculations. You can do empty and gross weight or just empty and do the math to get to Gross CG. However, you still need to know the proper CG envelope measurements from Datum Line. I can provide that information for a Firefly but not a FireStar2. Hopefully you have the manual with that info.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of artdog1512
Sent: Monday, March 29, 2021 12:24 AM
To: Kolb-List Digest Server
Subject: Re: Kolb-List Digest: 2 Msgs - 03/27/21
Larry
..... too fat Tim
