Epoxy Resin
albertakolbmk3
PostPosted: Mon Dec 28, 2020 6:58 am    Post subject: Epoxy Resin Reply with quote
Hello,
Is it critical to use the same epoxy as used when originally manufactured? I need to fill some holes and bond some pieces? After searching the internet I don't think it does, but just wanted to confirm here. I searched locally, but nobody carries it. Aircraft Spruce doesn't show it either.
Tony
Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop
peterz(at)zutrasoft.com
PostPosted: Mon Dec 28, 2020 7:07 am    Post subject: Epoxy Resin Reply with quote
Aeropoxy avail at ACS is the NA factory kit epoxy.
Cheers,
Pete
C-GNPZ
On Dec 28, 2020, at 10:04 AM, Tony Braun <albertaflyer(at)gmail.com> wrote:
Hello,
Tony
SteveIvell(at)pestproof.c
PostPosted: Mon Dec 28, 2020 2:18 pm    Post subject: Epoxy Resin Reply with quote
If it's not structural then I doubt it will be a problem if you use a similar 2 pack epoxy equivalent.
Steve
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Tony Braun <albertaflyer(at)gmail.com>
Sent: Monday, December 28, 2020 2:57:19 PM
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: Epoxy Resin
Hello,
Tony
graemeh
PostPosted: Mon Dec 28, 2020 3:07 pm    Post subject: Epoxy Resin Reply with quote
I was told by Europa that I could use West 105 resin with either the fast or slow hardener by Europa tech support.
On Tue, 29 Dec 2020, 11:23 Steve Ivell, <SteveIvell(at)pestproof.co.uk (SteveIvell(at)pestproof.co.uk)> wrote:
Steve
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)> on behalf of Tony Braun <albertaflyer(at)gmail.com (albertaflyer(at)gmail.com)>
To: europa-list(at)matronics.com (europa-list(at)matronics.com) <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Hello,
Tony
PostPosted: Mon Dec 28, 2020 3:35 pm    Post subject: Epoxy Resin Reply with quote
In north america its aeropoxy from aircraft spruce:
https://www.aircraftspruce.com/catalog/cmpages/aeropoxy.php
On Dec 28, 2020, at 6:17 PM, Graeme Hart <graeme.hart(at)onecoolkat.com> wrote:
Steve
Hello,
Tony
graemeh
PostPosted: Mon Dec 28, 2020 4:01 pm    Post subject: Epoxy Resin Reply with quote
I should have mentioned mine is a North American kit
On Tue, 29 Dec 2020, 12:40 Pete, <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
On Dec 28, 2020, at 6:17 PM, Graeme Hart <graeme.hart(at)onecoolkat.com (graeme.hart(at)onecoolkat.com)> wrote:
Steve
Hello,
Tony
