Europa pitot tube piping and connections
Chris Callicott
PostPosted: Mon Dec 07, 2020 12:36 pm    Post subject: Europa pitot tube piping and connections Reply with quote
Evening All, I am preparing a UK built (2007) Europa XS tri-gear which I purchased last year for a permit check flight. The aircraft has not flown for 7 years. I believe I have a leak in the pitot tube system. Pitot and static lines passing through the fuselage to the instrument panel seem to be made of semi-opaque hard plastic tubing approx 7.5mm OD and use 'push-fit' connectors. An adaptor connects the push-fit connector to standard ?6mm flexible clear tubing to the flight instruments.
Is this a typical arrangement in Europas and where would I source the larger tubing and push-fit connectors? Many thanks, Chris
