Glueing canopiesGlueing canopies
bkbrown(at)ashcreekwirele
PostPosted: Wed Jan 18, 2006 7:54 am    Post subject: Glueing canopiesGlueing canopies Reply with quote
<Guys, while we're on the subject, does anyone have any data on the weight
penalty, if any, of gluing as apposed to riveting? There's the obvious
advantage of less probability of cracking, but for some (those in warmer
climes) that's less of a concern.>
I used just under 2 tubes of Sikaflex 295UV to do the frame/canopy as well as all the canopy skirts...so my guess is would be just under 2 pounds weight penalty. BTW, the reason they started doing this in Africa several years ago had more to do with heat than cold, but I suppose it's the daily temp spread that causes the most trouble.
Bob Brown
RV7A - laying up plenum
