Europa W20 Bracket spec
barp99(at)gmail.com
PostPosted: Sun Oct 04, 2020 3:35 pm    Post subject: Europa W20 Bracket spec Reply with quote
Mike, you were absolutely right! Well spotted. I must have got the W19 & 20 brackets mixed up during alodyning, and have two W19 brackets on the other wing and two on this one.
I feel like such a goose. Hopefully I can swap it over without any further issues. Sure am glad for all the folk that offered help on this list, invaluable.
Cheers,
Brian.
On 4/10/2020 3:57 am, m.j.gregory(at)talk21.com (m.j.gregory(at)talk21.com) wrote:
<![endif]--> <![endif]-->
Brian,
From your photograph, it looks as though your ‘short’ bracket is at the root end of the flap, where the W19 bracket should be fitted.  The W20 bracket should go in the centre of the flap with a W21 pair at the outboard end.
Is it possible that you have selected both W20 brackets for this wing and have both W19 brackets for the other wing, instead of a W19 and a W20 per wing?  This would explain why things do not align.
Best regards,
Mike
Dr Mike Gregory
+44 1480 451655
+44 7885 355765
Brian Phillips <barp99(at)gmail.com> (barp99(at)gmail.com)
To: europa-list(at)matronics.com (europa-list(at)matronics.com);
02/10/20 00:56
11
61.4 KB
Save all as ZIP
I am currently attaching the port flap to the wing on my trigear, I find, for whatever reason, that the W20 bracket is too short by 12mm when the flap is in its correct position. Rather than live with this mismatch at the bolted joint, I will make up a new longer W20 bracket. Does anyone know what grade and temper these aluminium brackets are made from?
Brian
Sydney, Aus.
